L 3560 Dash Display
   / L 3560 Dash Display #1
Will_C
Veteran Member
Upstate N.Y.
Kubota L3560, Toro 52" and 60" ZTRs, Kubota RTV 900
I bought a L3560, and am in the process of figuring it out! One thing I can't find in the owner's manual is how to reset the speed and fuel displays from metric measurements to English. Anyone have any advice for me?
Thanks,
Will
   / L 3560 Dash Display #2
Starting with the tractor parked and engine off, turn the key switch to "on" while holding the display mode switch down (button on the console on the left). You should see a screen labeled Service Inspect and a bunch of letters. You should then be able to use the display mode button to scroll through the choices to select J with short button pushes. Open J with a long button push. This is the speed unit input mode. Choose the English units.
To exit this screen turn key to off. (Just tried it again since it had been a while, and even though there is an OK that you might think you could highlight and exit, I could not, but turning key off saved the change.)
Note: the other letters lead to adjustments you shouldn't change!
Thank you very much! I'll try it out tomorrow. Not much of an issue, but I think having the speed in mph will be helpful to maintain a constant speed when I am spreading fertilizer and seed.
Will
Thanks again. Worked just like you explained. Frustrating that something like that isn't in the manual. Will
   / L 3560 Dash Display #5
No problem.
Now you know you can use your tractor in both Imperial AND Metric!
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A50854)
2014 FORREST RIVER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
