L 2850, Battery good nothiing else works electrically
   / L 2850, Battery good nothiing else works electrically #1
wve
lampasas, tx
1987 L 2850
Had been using tractor. Killed it and it will not do anything electrically. No dash lights or other functions. Fuses good.
   / L 2850, Battery good nothiing else works electrically #2
Check the ground connection. Kubotas are notorious for bad battery grounds.
Attach one lead of a jumper cable (black) between the battery negative and the engine block. Disconnect the existing ground cable so you can directly attach the jumper cable to the battery post.
While you are there, make sure the positive connection is clean and tight.
   / L 2850, Battery good nothiing else works electrically #3
If that doesn't work, check for fusable links... usually located in the harness at the starter terminal connection. See if one of those is burnt in two.
eXmark Quest Zero Turn Mower (A53117)
eXmark Quest Zero...
2005 FORD F350 XLT SUPER DUTY SERVICE TRUCK (A51406)
2005 FORD F350 XLT...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
PRINTER (A53843)
PRINTER (A53843)
