Geeze, since I started digging a hill for a new garage last December, my L-2800 has broken down three times. First, bolts broke off in the sub-frame of the loader. Second, a hydraulic cylinder shaft warped (now straightened and working again).
NOW............ the tractor cranked fine earlier today. I turned off the engine after a couple hours and it would not re-crank.
Here is what I did:
Hooked up charger. When I placed it on "50 amp boost," the meter showed a charged battery!! (What th' heck?)
With CHARGER HOOKED UP, the solenoid was clicking and all dash lights on, but engine would not turn over.
With CHARGER UN-hooked, no lights and nothing happened.
I cleaned battery terminals, checked all the fuses, and connections - - everything OK. I even tightened up a slightly loose belt on the alternator, but figured this would do nothing because it cranked fine earlier.
Battery is 5 1/2 years old. Tractor is 2009 model. I was going to replace the battery soon.
QUESTION: Should I try a new battery first? OR................is it the starter? .................solenoid???
What th' heck could it be??
Why would the charger meter show full charge, but when un-hooked, no dash lights come on? Is the battery suddenly "so-dead" that nothing works?
THANKS so much for reading this.
Take care, Bo in NC
Here is what I did:
Take care, Bo in NC
