L 2500 front loader
/ L 2500 front loader #1
L 2500 owner
Boyne City, MI.
Kubota L 2500
I recently purchased a L 2500 without a front loader and checked around for a loader, I found a loader that the local kubota dealer said was used on my tractor a LA 402. The individual selling the loader had the loader on a 2910 and told me it would fit my tractor and after talking to the dealer I bought the loader. As near as I can tell the mounting bracket is somewhat different but I am unable to get a good picture of the correct bracket. Can someone enlighten me on what the correct bracket might look like.
/ L 2500 front loader #2
Hi L2500.
The loader for the 2500 is an LB400 and the LA402 is similar but not exactly the same. You can see pics of the L2500/LB400 loader - just google and also for the LA 402 on the 2910.
Why dont you put us some pics of the loader and tractor and also look where the frame mounts to the belly of the tractor and the front grill area?
Carl
Thanks for the quick response I will try to get the pics up of the tractor and the mounting bracket of the LA 402. Just called the dealer and he changed his story and says the 402 fits a b series and not a L series and that a welder may be the only way the bracketry will ever work.
iDrive TDS-2010H...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
2016 JCB 510-56 10000 LB Telehandler (A64047)
2016 JCB 510-56...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
