L 2250 Hydraulic pump reseal
   / L 2250 Hydraulic pump reseal #1
albe123
Boerene,Tx
Kubota L2250
The level of crankcase oil keeps increasing. I'm assuming its a problem with a the hydraulic pump seal. I have power steering so its a dual unit. I thought I had read somewhere not to try to rebuild that unit. Is there a problem in rebuilding? The parts are available. Has anyone done it and could advise me?
Thanks, Al
   / L 2250 Hydraulic pump reseal #2
Most of the time the seal is pushed out due to a worn pump allowing pressure to leak up the shaft. You can try a new seal. But once the aluminum pump housing wears out. The price of rebuilding pretty much adds up to what a new pump would cost.
All new seals for both units were available....about 13 seals and metal seals. These parts about $60. vs about $400 for new pump if it's available. Has anyone tried to rebuild/reseal this unit?
Al
Yes, I finally did rebuild the pump. Have about 3-4 hours on it and so far, no noticeable increase in crankcase volume.
Probably not enough time for a reasonable response!
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
BUSH HOG 2820 LOT NUMBER 128 (A53084)
BUSH HOG 2820 LOT...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2012 FORD F-550 SUPER DUTY FLATBED (A52472)
2012 FORD F-550...
