l 185 problem
   / l 185 problem #1
turbo raptor
l185
i have an L 185 skidsteer and i have a problem. it runs and starts fine,but every once in a while it cranks but dont start. when it does this i jump the fuel selonoid with a hot wire from the battery and it starts, take it off and it stalls. checked volts to harness when unplugged fine, but the second the contacts touch on the plug loss of power. btw this is the plug fron the tractor to the seloned. the machine sat for about 1 hour and it started fine for the rest of the day. what the heck is going on please help
   / l 185 problem #2
I don't know the details of your SS, but I'd bet you have a relay that drives the solenoid and the relay has burned contacts. You can measure voltage, but as soon as the solenoid draws current, the contacts heat up and open. Only when the contacts are making good contact will they be able to supply proper current. I'd look for that relay and replace it.
2013 Ram 1500 Pickup Truck (A51692)
2013 Ram 1500...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
Serco 270 Log Loader (A52384)
Serco 270 Log...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2016 KENWORTH T270 SERVICE TRUCK (A51406)
2016 KENWORTH T270...
