aesmith
I posted earlier about starter problems, but I thought I was all sorted fitting a European (WAI) starter rather than the Chinese most offer.
www.tractorbynet.com
However unbelievably that starter is now dying in the same way that the EBay one did. It's sluggish to turn and can barely start the motor sometimes. Here's an example, cold start and battery freshly charged (actually sometimes it's a lot worse than this) ..
Of course I checked all connections, checked the battery was charging etc. Just as a last resort I remitted the old intermittently faulty starter and did a cold start this morning. The difference is night and day ..
I really dont know where to go with this. Is there any way the machine can be killing starter motors? Or something I'm doing? I still don't know what causes the intermittent fault on the old starter, I've stripped it and tested on the bench and nothing seems wrong. So for the moment that's where I am, one lively starter that sometimes doesn't work at all, two replacements with various degrees of crappy operation, but without the intermittent problem.
Waiting to hear back from the dealer about the new WAI starter. But would welcome any comments or suggestions.
D1105 Starter Issues
Hi, The engine is a D1105-BH fitted to a KX41 digger rather than to a tractor, in case that makes a difference. The starter intermittantly doesn't work, the solenoid draws power but doesn't move or doesn't energise the motor for some reason. First time it did this was after a lunch break, so...
