kudzu....
/ kudzu.... #1
randy41
Veteran Member
Linden VA
i need to cut kudzu vines down from the trees that are too high to reach from the ground. i'm not looking to eradicate the kudzu this way but i want to use the vines to make baskets. i need to use long pieces. what inexpensive tool should i get to do this?
/ kudzu.... #2
Kind of a stale post, but...
When I was working for a land surveyor in East Texas as a teen, we always used what we called a "brush knife" but it's proper name is probably a long handle "brush axe", it can be sharpened around the entire edge and worked well on vines and doubled as an axe.
/ kudzu.... #3
I have always known that tool as a "ditch bank blade". Whatever it is it is a very useful blade.
Since this is a tractor forum and we strive to do everything by tractor look at a Hi-Reach Tree Shear. I have one and used it to get wild grape vines out of my oak trees. I am able to reach up nearly 14' with it. The vines had almost killed some of my oaks.
Vernon
/ kudzu.... #4
Home Depot sells an awesome cutter by Fiskars called a "Pruning Stik" (model 9234) for about 40 bucks. It's a 62" long pole with cutting jaws at the end. You can reach way up above your head, pull the end of the handle, & the jaws cut. This thing is slick, works really great & with minimal effort.
I bought one, wore it completely out, then bought another, used (abused?) it until I broke the rope inside it. Was about to buy a 3rd (I love this thing!) when I realized it has a lifetime warranty!! (Wasted my 40 bucks buying that 2nd one - Drat!)
Very light (less than 2 lbs) but incredibly strong. The fact that I've worn them out is not because they're weak; It's because I use the heck out of them & probably cut stuff bigger than I should, using all my power.
I see Fiskars also now sells a telescoping version, model 9240, extends to 12 feet & with a cutting capacity of up to 1.25", even includes a 15" saw blade that can be attached, & looks to be about 85 bucks.
I'll have to ask for the telescoping model for Christmas! :laughing: :thumbsup:
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
2011 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2011 Dodge Ram...
2025 32in. Tilting Bucket Mini Excavator Attachment (A61572)
2025 32in. Tilting...
2021 Exmark Lazer Z 60in. Commercial Zero Turn Mower (A61572)
2021 Exmark Lazer...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
HARDEE 200 GALLON POLY TANK SPRAYER, 3PT (A63291)
HARDEE 200 GALLON...
