There are bushings in the frame where that rod rests. Those bushings have a flat spot on one side. Slide the bushings on to the rod, then slide the rod to one side. Then pull the other side of the rod towards you, and slide the rod and lower links out.
This from another post a couple years ago.
This is to install. Reverse these directions to remove.
Hope this helps.
