Kubota ZD326 or Ferris 4500 ZTR ??
   / Kubota ZD326 or Ferris 4500 ZTR ?? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
I have been looking at the new Kubota 326 pro with the 26hp diesel engine with 60 inch cut and the Ferris 4500 model with the 28Hp cat.diesel 61 inch cut.I have been told by the sales people to stay with the twin hydro and two wheel motors on the ferris.How does the Kubota 326 pro stack up againest the ferris.I have been quoted $10,700 for the kubota and $13,725 for the Ferris.Thanks for any information.coobie
   / Kubota ZD326 or Ferris 4500 ZTR ?? #2
I'm partial to the Kubota in that comparision. The Ferris is a good brand but not that good if both were the same price.
   / Kubota ZD326 or Ferris 4500 ZTR ?? #3
Consider the suspension on the Ferris. That's a feature the Kubotas don't have.
IMHO, if you go with the Cat Diesel, you should consider the 72" deck.
   / Kubota ZD326 or Ferris 4500 ZTR ?? #4
On the suspension, I like it to a degree as we've sold thousands of them being their first dealer and involved with them before they introduced them. Sometimes a bigger tire might not fall into as many holes as a smaller one.
Thanks for the information.I ended up buying the Kubota 326 pro 26 hp diesel with the 60 inch deck.Fingers are crossed,I hope this ZTR is dependable.coobie
   / Kubota ZD326 or Ferris 4500 ZTR ?? #6
As far as a machine, the Kubota is quality above the Ferris.
As for the engine, Kubota has a proven engine, day in and day out...but nothing runs like a Cat..... They are bullet-proof.
All in all, you did well....... You'll be pleased with the orange machine.
   / Kubota ZD326 or Ferris 4500 ZTR ?? #7
I sell them both, and I would agree that the Kubota drive system is way better than what Ferris (or anyone else) is offering. The suspension is the sole reason we carry Ferris, it does work. If your ground is so rought that you must have it, buy Ferris. Otherewise your getting a better machine for the money with the Kubota.
I mowed tonight for the first time with the new kubota 326 pro.here are my observations,pros-very heavy duty deck,nice seat,good controls,great engine,and mows very nice to boot.The only con I can find is that the ride is rougher than my old 2004 ferris I had with independant suspension.All in all the kubota 326 is quality ZTR.coobie
   / Kubota ZD326 or Ferris 4500 ZTR ?? #9
Check your rear tires air pressure. If they are at the maximum recommended then drop them to about one half of that and then check the ride! The fronts are flat free!
I'll normally pick the home team in any game and the kubota is definitely in home court when it comes to the small diesels! Cat has done well with the perkins line of engines but knowing the noise levels of both engines well, I'll take the Kubota!
Good info Art,I will check the tire pressure first thing tomarrow.coobie
2017 Peterbilt 567 Tri-Axle Dump Truck (A49461)
2017 Peterbilt 567...
DMI 3200 Side Dress Bar (A50514)
DMI 3200 Side...
JLG ELECTRIC MANLIFT (A50854)
JLG ELECTRIC...
1996 Eager Beaver 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2009 MACK CXU613 DAYCAB (INOPERABLE) (A50854)
2009 MACK CXU613...
