Kubota ZD25 zero turn mower with safety switch problems!
   / Kubota ZD25 zero turn mower with safety switch problems! #1
MiltyOO
Hollywood, SC
First I have looked at the elect. schematic to find the location of all the switches, but how in the heck do you even get to them to check them?
Mower starts fine if I disconnect the wire to the solenoid and jump across the hot to the spade.
Help the newbie!
   / Kubota ZD25 zero turn mower with safety switch problems! #2
the motion control lever (neutral) switches are accessible from under the fenders. The PTO switch is behind the PTO lever-easy. The brake switch is under the floorboard inside the C-channel frame rail, IIRC and a pain to get to. It's usually the pto switch or the OPC controller. Rarely the brake switch or either of the 2 neutral switches.
2014 WESTERN STAR 4900 SF (A45333)
2014 WESTERN STAR...
2017 Ford F-250 Pickup Truck (A44572)
2017 Ford F-250...
PORTER CABLE 150 PSI AIR COMPRESSOR (A45333)
PORTER CABLE 150...
2020 Chevrolet Tahoe SUV (A42744)
2020 Chevrolet...
2020 LGMG AS4046E ELECTRIC SCISSOR LIFT (A45046)
2020 LGMG AS4046E...
ALL-STEEL CARPORT W/OPEN SIDEWALLS (A45046)
ALL-STEEL CARPORT...
