Kubota ZD21 engine not stopping for a few minutes after being turned off
   / Kubota ZD21 engine not stopping for a few minutes after being turned off #1
mail4tom
Kubota ZD21
I have this Kubota ZD21 Diesel tractor. After mowing the grass I turned the tractor off. It did not stop for about two minutes. I tried again and it did the same thing. I then engaged the mowing deck and stood up. The Tractor kept of running. I disengaged the mowing deck and then waited a few minutes for it to shut off. The engine sounded a bit rough and there was a little bit of vibration as it shut off. Can anyone provide me some guidance and direction on resolving this issue. The tractor operates normally in all other aspects.
Tom
   / Kubota ZD21 engine not stopping for a few minutes after being turned off #2
I think it should have an electric fuel solenoid that is slow in closing, you may have to disassemble it and clean it or replace. Just a guess.
   / Kubota ZD21 engine not stopping for a few minutes after being turned off #3
Fuel stop solenoid, recommend replacement cleaning is iffy
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2004 Hydraulic Breaker Excavator Attachment (A49461)
2004 Hydraulic...
