kubota zd 321 21hp diesel
   / kubota zd 321 21hp diesel #1
johndeere1kubota2
Mississippi
John Deere 990
Is the ZD 321 Kubota zero turn mower with the 21hp 3 cylinder diesel motor and 54" deck an adequate pairing of motor and deck width combination. I have 4 1/2 acres of yard that i have been mowing with a 50" Cub Cadet purchased from Lowes with no problem. Just looking to upgrade to a commercial mower for the long haul........
   / kubota zd 321 21hp diesel #2
Yes it is. The prior model, ZD21 run a 60" deck with 21Hp. Given your acerage, I'd look at a ZD326S. Its only marginly more expensive and will help you get done quicker.
Thanks for the information. I will ask for the demo ride on the 326s when i return to the Farmbelt dealership.
   / kubota zd 321 21hp diesel #4
I have a ZD21 with the 60" Pro deck and I have had no problems and the engine handles it fine. I am mostly on flat ground though, if you have lots of hilly terrain I would recommend you look at the 326 also. Good luck
   / kubota zd 321 21hp diesel #5
There is a bit more weight on the newer model ZD's and they did turn up the speed a bit so the extra horsepower of the 326 fit's the 60" deck a little better for some operators.
   / kubota zd 321 21hp diesel #6
I mow five acres with the previous model, the ZD 21. Even with long, wet grass, it has never had a problem. Of course it is all level. Great mower.
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2015 DODGE RAM...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
