Kubota Z421 2017yr
   / Kubota Z421 2017yr #1
Louieb
Kubota z421
Can anyone help me out with issue on my Zero turn? I have it running with PTO on I deciding to lift my body off the seat for a split second engine decide to die stop running but i get back on the seat continue to mow grass motor is running park brake engage and lock left & right handle are back to neutral , then i try to lift off seat and motor wants to stop when i want to get off the mower so i could not leave the seat for 2 hours and i finish cutting the grass, then pull it in the garage shut it down then try to start it up nothing ! won't start waiting few minutes then it turn over!!!
any help any ideas, dumb founded!!!!
Louie B
   / Kubota Z421 2017yr #2
Your operator's manual likely has a testing procedure for the various safety switches. Your description is a little hard to follow, but it sounds like the pto switch is / was preventing starting.
i believe you are correct on PTO switch if i have the blades running and i lift myself off seat before i turn off PTO engine wants to die, its happening often so i guess i must wait for blades to stop before i get off zero turn!
thanks for your input
80in HD Tooth Bucket with Side Cutters (A52748)
80in HD Tooth...
2008 Ford F-250 Ext. Cab Pickup Truck (A50323)
2008 Ford F-250...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A52141)
2016 INTERNATIONAL...
2011 Manac 36245B30 45FT T/A Walking Floor Trailer (A50323)
2011 Manac...
Genie GTH1056 (A50120)
2025 JMR 36in Bucket Mini Skid Steer Attachment (A50322)
2025 JMR 36in...
