Tire Selection Kubota z411-48 tire replacement for better traction
   / Kubota z411-48 tire replacement for better traction #1
frogpond
Snohomish WA
Kubota BX25D
I am thinking of replacing the turf tires on my kubota z411 mower with something more aggressive to reduce sliding on hills, especially when it's wet. I would be happy to find my adventures elsewhere, and it would be nice not to have to assure my wife that I didn't mow her plantings through carelessness.
The problem is that I can't find anything that matches the size of the stock tires, which are 25x9.5-14. Should I get a different size tire, different wheels, etc? Any specific recommendations are appreciated.
   / Kubota z411-48 tire replacement for better traction #2
I wanted the same thing on my 2400. My tractor originally came with Industrials. I wanted a softer ride so I thought turfs would do the trick. To get a turf I had to change wheel diameter from 16.5" (an industrial equipment diameter) to 16". I bought new wheels and the turfs and to my dismay and financial loss, the sidewalls were as stiff as the Industrials, 4 ply.
Since I now had a standard wheel, I easily found 16x6 R1 farm lugs which not only greatly improved my traction, giving me new applications for the tractor, the sidewalls were softer, allowing for a softer ride with the low air pressures I normally ran. In the tire swapping, rolling circumference was the main thing to watch since, like most newer compact tractors, 4wd compatibility is a concern for proper front to rear traction.
Additionally, before I gave up on the OEM installed industrials, I had added a significant amount of rear axle weight via bolt on weights that I scrounged around and found that fit my wheel bolt patterns. So, thinner tire, very aggressive lug, added rear wheel weight, made for a real tugger in a little guy and hillsides were no longer a consideration besides not adding it to my field work capable machines.
I left the OEM Industrials on the front as I wanted a wide, short, stiff sidewall for FEL work.
2007 TRANSCRAFT 48X102 FLATBED (A50854)
2007 TRANSCRAFT...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
71059 (A49346)
71059 (A49346)
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
