Mowing Kubota z125s
   / Kubota z125s #1
Kudzu Killer
Finksburg, MD
Yanmar LX4100
I have been using a z125s for the past 3 years mowing around the farm. This summer it began having some trouble starting. I charged the battery and it started right up for several weeks. Then the clutch started to disengage while mowing and it would not start. I replaced battery and no issues for several weeks. Now same issue, clutch disengaging and won't start. I am guessing the battery is not being charged. I checked wiring and it all looks intact. I am charging the battery after every use but not a long term fix. What's the next step? generator replacement? Any help appreciated.
   / Kubota z125s #2
First would be to verify if the unit is not charging! Simple regulator exchange might be the end to your problem! The longer you run an electric clutch with a shortage of power the quicker it will destroy itself!
   / Kubota z125s
Thanks. That would be a simple fix. I will give it try!
Quick Attach Pallet Forks (A47384)
Quick Attach...
2014 International Durastar 4300 Terex BT3063 30,000lb 63ft Crane Truck (A50323)
2014 International...
2008 CATERPILLAR 140M VHP MOTORGRADER (A51242)
2008 CATERPILLAR...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2007 MACK GRANITE  TRI-AXLE DUMP TRUCK (A51222)
2007 MACK GRANITE...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
