Beccat1
Sure hope someone can set me on course! Bx2200 had no lights, glow plugs - checked ignition switch, looks good. 30 amp fuse which sticks out by the oil filter was open. Changed that, had all panel lights and glow plugs - turned key on to start and it did but then died. 30A fuse blew again. Noticed a blue wire broke from it's connector, attached to a lug on a component that may be the oil pressure switch. Any idea if that component is the oil pressure switch?
I will fix that tomorrow and pick up a couple fuses but don't want to keep blowing fuses.
I also found a loose nut touching a bar with a black/red wire attached to it and it looks like that nut did arch to the bar a bit.
Any ideas?
Any ideas?
