Kubota with cab and 60" snowblower
   / Kubota with cab and 60" snowblower #1
milkie62
upstate NY
Kubota M6800,Ford 801,MF 65, Kubota L305
Been looking around for a cab Kubota with mid pto for snowblower work. I am retiring and buying a new truck and do not want to be pounding on it snowplowing approx. 1400 feet of driveway. Grabbing a coffee sitting in the tractor with heat and radio is the way I want to go. I do not need a bucket since I have a M6800 with bucket already. I was thinking in the 30 HP range since I do not want to spend too much. It may be used for some rear finish mowing work in the summer but mostly just snowblowing. Will 30 HP be sufficient for a 60" snowblower. Don't trust dealers sometimes on their recommendations.
   / Kubota with cab and 60" snowblower #2
30hp is plenty to drive a 60 inch snow blower. I ran a 72 inch blower on a Kubota L3410 tractor with about 28hp at the pto for years without issue.
I prefer rear mount blowers, but front or rear, the blower should be sized at least wide enough to cover the tractor width (plus an inch or two).
Happy shopping!
   / Kubota with cab and 60" snowblower #3
I think a B2650 HSTC would fit the bill.Only negative I have read is that it is noisy in the cab.
   / Kubota with cab and 60" snowblower #4
Don't forget some ballast. If you hang a snowblower off the back end without a loader, you may have light steering; make sure you get some front-end weights
   / Kubota with cab and 60" snowblower #5
Consider getting a HST tractor. Even though the HST trans robs a few HP from the PTO, the variable speed makes snowblowing a lot easier. I used a Woods 74" snowblower on my old L3430 (29 PTO HP) with no issues. If you are planning on using a 60" blower, make sure the track width of the tractor you choose is a couple of inches narrower.
Don't plan on being able to use a radio effectively in the noisy cab of a compact tractor. I have much better luck with radio equipped headphones or one that plugs into an iPad.
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2021 Ram 1500 Bighorn (A53472)
2021 Ram 1500...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
