Kubota Transmissions
   / Kubota Transmissions #1
Dissolute
I've driven and like the new M5040.
Please describe the pros and cons of the mechanical shuttle vs. hydraulic shuttle transmission.
I left a discussion with the salesman still not understanding the difference.
Thanks in advance.
   / Kubota Transmissions #3
Also, this TBN discussion of HST shows that it takes some explaining.
My net is that, for me, HST, is superb... I don't do much plowing but lots of general use of the tractor around the ranch. Try driving both and it may help you understand the differences.
   / Kubota Transmissions #4
The mechanical shuttle uses a dry single disk clutch plate. The hydraulic shuttle uses a wet "Multi disk" clutch pack housed inside of the transmission. The latter is MUCH stronger and less apt to wear out.
Thanks for the information.
Therefore, as I understand it, hydraulic shuttle shift will allow me to go forward or in reverse by merely shifting the selector on the column (and not having to depress the clutch.
Please confirm.
Thanks again.
   / Kubota Transmissions #6
You talk about shifting a selector on the column... no clutch depression. I familar mainly with my Kubota 5030 HST and will describe how it works... in practical terms. I don't know exactly what selector is on the column of the tractor you are referring to.
First, I decide which speed/gear/power I need to use and set the manual gear selector under my left hand... high or medium or low. Gotta use the clutch for this and be stopped.
Then while stopped, I set the RPM's using the column RPM stick.... I most usually run at 1500 when doing light/medium work.. more or less RPMs as the situation warrants.
Then, the tractor is ready to move... there is a rocker pedal under the right foot... rock it forward slightly to move forward slightly... rock it back with the heel of the shoe and forward motion will stop and it will reverse. Return to neutral and motion will quickly slow to a stop.. unless on significant incline it will not slip or creep... no clutch needed. The amount of forward/reverse depression of the foot pedal adjusts the forward/reverse speed... all within the same RPM setting. More forward/down means faster forward. More reverse/down means faster reverse. All this is without hitting the clutch.
This means you can (with practice) drive right up into a pile of sand with the FEL, and with continuous motions fill the FEL and start your reverse motion... all with no clutch and only rocking your foot forward or back... then speed forward to the point to dump it... let up on on the toe presssure while using the FEL to dump the load... and hit the reverse heel rocker and back away, turn and proceed forward to the sand pile again.
Bottom line is that I can do this a lot in one day and not get a tired leg from pressing the clutch.
Hope this helps.
   / Kubota Transmissions #7
</font><font color="blue" class="small">(
Hope this helps. )</font>
I have used the rocker pedal on a 3830. Do you keep your right foot on entire pedal, with toes on front and heel on back, rocking back and forth, or just press on front, then when you want to go in reverse, pick up your heel and press on rear pedal to go in reverse. I tried keeping my entire foot on the rocker pedal, but my foot seems a little small. My size 12 is just a bit to small to set comfortably on both parts at the same time. I am sure it is a technique issue. So what am I doing wrong?
Bob
   / Kubota Transmissions #8
The only time you depress the clutch on a M series with shuttle shift of any kind is to shift gear ranges. To switch from forward to reverse or visa versa you just come to a stop and move the shuttle lever on the steering column. You can depress the clutch when you come to a stop but it is not necessary
   / Kubota Transmissions #9
That is not so. I have an M4900 with the mechanical shuttle and the manual clearly states its use requires the use of the clutch. I have never tried it without the clutch and would not. It also says you do not have to come to a complete stop to shift from forward to rev or vise versa but to use caution as a sudden shift can cause damage.
Dave
   / Kubota Transmissions #10
The M series that end in a HD you can shift between forward and reverse with out clutching because they are hydraulic shuttle shift transmissions the others you must clutch. The others are mechanical shuttle shift transmissions.
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
Hydraulic Hose Reel (A49461)
Hydraulic Hose...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2016 CATERPILLAR CT660 TRI AXLE DUMP TRUCK (A51222)
2016 CATERPILLAR...
Unused 2025 CFG QK16R Mini Excavator (A49461)
Unused 2025 CFG...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A49461)
2018 JLG 1644 4x4...
