Kubota tractor
   / Kubota tractor #1
Mwhite1929
L3400
Hello new here my L3400 Kubota rear housing cracked when I was trying to get the pin out where the propeller shat goes in can I just buy the housing?
   / Kubota tractor #2
Welcome to TBN. You probably would get more help with a little more information and a few pictures. Are you talking about the PTO shaft?
Don’t remember seeing anyone crack a housing removing a PTO shaft but seen plenty crack from have too long of a shaft on an implement. The damage occurs when they lift the implement with the 3pt hitch.
   / Kubota tractor #3
The rear case cover on my M9's is removable and replaceable but it's not cheap. You might find one at a tractor salvage yard. Not sure about yours but I presume it is.
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
2013 Ford Transit Connect Van (A52377)
2013 Ford Transit...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
1996 Timpte 46ft Hopper (A55301)
1996 Timpte 46ft...
