I've had my
B2620 for a few weeks now. I use it primarily for mowing. The cut quality if fantastic. It is very maneuverable. The loader is very easy to put on and take off. The three range hydro is great - I can mow fairly steep hills in mid range. The 2920 should be even better with the extra power.
When I was tractor shopping, I was initially comparing the
B2620 to the JD2320. Their engines have almost identical displacements. I assumed that the JD must have been set up with a lower HP number but greater low end torque. But when you check the torque numbers in the Kubota owner's manual, you find that it has a lot more torque, at about the same rpm.
The B2620 is actually comparable (actually superior) to the JD2520 in terms of power and torque, even though the JD has a much greater displacement - don't know how Kubota does it. So the
B2920 should be a really strong machine.
