Traction Kubota track adjuster acess
   / Kubota track adjuster acess #1
ozfossil
Kuranda
kubota k030 excavator
Hi All,
I own an old 3 ton Kubota excavator which has a leaking track adjuster - from reading as many related posts on this site as I could, I gather I will need to remove the adjuster and repair leaking seals etc. On looking at the operators manuals and everything I can see on the net, I am mystified how I would get to it. Any one have any experience or knowledge on where to start? My model is a K030 (very similar to the KX91-2).
At the moment I am thinking that the track has to come off, then the idler wheel removed and then perhaps the Adjuster might be able to be pulled out (ort not!). I am hoping though that a few bolts would remove the side cover and I would get to it much easier. Looking at that seems to be attached to the side cover - this is not looking likely.
Thanks in advance for any thoughts
Cheers
Peter
Kuranda QLD Australia
Oops that last sentence should read "Looking at What seems to be attached to the side cover-......"
I could not see any way of editing my post - if there is a way to that I would appreciate knowing for next time?
Cheers
Peter
2018 Kinze 3500 Planter (A52349)
2018 Kinze 3500...
2006 Toyota Highlander SUV (A50324)
2006 Toyota...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2016 FREIGHTLINER...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
JMR 68" Root Grapple (A50121)
JMR 68" Root...
