Kubota TG1860 Transmission problem
   / Kubota TG1860 Transmission problem #1
rhoch68
I mow an acre at a 35 plus degree slop. The trans went out at about 100 hrs. of operation. I was told that I should use a heavier trans oil to prolong the life. Is this a solution to early failure? What should I use?
   / Kubota TG1860 Transmission problem #2
Told by whom?
What's the maximum slope your machine is designed to operate on? If you're exceeding that spec, it's unlikely switching oils will help. If components were subjected to oil starvation damage due to operation on an incline, then simply starving those components from heavier oil isn't going to fix anything....
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A50323)
2007 Western Star...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
2010 HEIL TOKEN TRAILER (A52472)
2010 HEIL TOKEN...
378754 (A51573)
378754 (A51573)
ATTENTION PLEASE READ (A50120)
ATTENTION PLEASE...
2008 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2008 Ford F-150...
