Kubota Starter Solenoid
/ Kubota Starter Solenoid #1
Jere
I have a Kubota B2400 with a bad starter solenoid. Anyone know a palce on line where one could be ordered? I have been unable to locate the item. Thanks so much. /forums/images/graemlins/confused.gif
/ Kubota Starter Solenoid #2
Try Tractorsmart.com.
If you are not in a hurry there are offers on ebay sometimes.
All the best,
Martin
/ Kubota Starter Solenoid #3
You could also try Carverequipment.com. They are good to deal with and will help you diagnose the problem if you ask.
/ Kubota Starter Solenoid #4
Are you absolutly sure you have a bad solenoid? 95% of the time the problem is low voltage going to the solenoid due to high resistance in the safety switches, and ignition switch (which seems to keep getting worse over time). Look for information in this forum from a member named KUBMECH. He very clearly detailed the installation of a John Deere relay kit that costs approx. $20.00. I have a B2400 and struggled for a year and a half with clicking when starting the tractor. The kit solved the problem in 20 minutes! Try to measure the voltage going to the solenoid. If it is less than 8.5 volts, you will have problems, and a new solenoid will not help. The relay will operate as low as 4 volts, and allows 12 volts to go directly to the solenoid.
Good luck,
2007 FRAC TANK 500BBL WHEELED (A63569)
2007 FRAC TANK...
7102 (A61567)
7102 (A61567)
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
378909 (A61166)
378909 (A61166)
PORTER CABLE AIR COMPRESSOR (A63569)
PORTER CABLE AIR...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
