Kubota ST30 3 point linkage failure
   / Kubota ST30 3 point linkage failure #1
mogsareus
Kubota ST30
I have an 800hr ST30 which I have had for around 20hrs.
After using it for 2 hrs today with a 1.3M fail mower I found, just as I returned to the workshop, that the linkage dropped and cannot be raised.
I have clean out the hydraulic filter, which did have contamination, but not enough to block it as the hydraulic outputs still pressurised.
The machine is in nice condition, but has been lying for some time prior to my purchase.
I can only think of accessing the actuating valve to see if the linkage has come adrift (although it doesn't feel as though it has) or that I have contamination in the valve that is holding it open.
Advice/experience would be welcome.
   / Kubota ST30 3 point linkage failure #2
Put a hyd gage in your hyd system, and the readings should lead you in the right directions.
Many thanks for your reply J_J.
This proved to be a simple one - a broken link between the hydraulic valve and the 3 point linkage arm casting.
Cause. The pivot in the linkage casting seized, the 8mm round bar was then bent too and fro as the linkage was operated.
In carrying out the work to identify the problem - in a machine with a factory cab on it - I have made a simple modification to allow the panels below the tool locker to be removed without taking the cab off - details available if anyone is interested.
2012 Caterpillar 259B Compact Track Loader Skid Steer (A51691)
2012 Caterpillar...
Hyster H225E (A47384)
DESK (A53843)
DESK (A53843)
2003 Chevrolet Silverado 2500HD Ambulance (A51692)
2003 Chevrolet...
2017 Chevrolet Tahoe SUV (A51694)
2017 Chevrolet...
2020 Caterpillar D5K2 LGP (A50123)
2020 Caterpillar...
