Kubota snowblower B2551 compatable with JD?
   / Kubota snowblower B2551 compatable with JD? #1
Ezlivn
Robbinston Maine
2001 JD 790
Just because this is a Kubota brand...would it fit on my JD790? Thanks
   / Kubota snowblower B2551 compatable with JD? #2
Are we discussing the rear mount blower on CL? If so.... it should work as long as its designed to run on a 540rpm pto. I would assume it is. I do believe that if you paint it green, you will spend eternity in Hades though...... :eek::eek:
Yup Ductape that's the one. You're alot closer to it than I am though. I'm gonna pass on it and probably kick myself for it but I'm a good 5 hour drive to Sanford.
I'm gonna use my FEL for this winter and keep an eye out for a blower for next Winter.
Ok I have to admit...I Googled "Hades" lolololol
   / Kubota snowblower B2551 compatable with JD? #4
The only reason i'd question that one being 540 rpm is that it looks fairly old. Alot of older machines have multi-speed PTOs..... so it could be concievable it could be designed for a 1000 rpm pto. Unlikely, but possible. FWIW, six beans is relatively short money for a blower..... even though it could use a dressing up.
I figured i might get in trouble for using the h e double hockey sticks word.
Loader Bucket (A55787)
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
Utility Trailer (A52377)
Utility Trailer...
1992 Ford F-150 Pickup Truck, VIN # 1FTDF15Y3NNB06697 (A51572)
1992 Ford F-150...
2015 Ford Transit 250 Cargo Van (A55788)
2015 Ford Transit...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
