Snow Kubota snowblade problem
   / Kubota snowblade problem #1
pajohn
Today I was plowing snow when my snow blades electric lift actuator on my RTV quit working in the full up position.
I tried to get it moving by moving the rocker switch. Nothing happened. It's stuck in the up position? I wonder if its the electric motor or the switch. Any thoughts out there? Any experience with this Kubota 72" snow blade
PA, John
   / Kubota snowblade problem #2
I don't have one, but have had a few plow blades in the past. First start by checking the connections and make sure they are clean. Then give em some of the special grease for electrical components. Thinking computers, I would unplug the battery then reattach it.
Good Luck.
   / Kubota snowblade problem #3
Check your fuses. Get someone to work the switch and check with a test light to see if you have power going to the actuator.
   / Kubota snowblade problem #4
And check grounds.
   / Kubota snowblade problem #5
If the simple checks fail, get a voltmeter and see if you have 12v at the motor. If not, work your way back to see where the voltage disappears.
I had the connector fail on mine, I replaced it with a flat 4 prong trailer light connector.
   / Kubota snowblade problem #6
Did you find out what is wrong with it?
   / Kubota snowblade problem #7
PA, John
Mine did the same thing...The fuse blew out...It's hard to hear the actuator hit dead top and holding the rocker will blow the fuse.
Thanks guys for you insight into my Kubota snow blade problem. I checked all fuses in the fuse box for continuity and visually inspected them. All were good. While closing the bed I noticed a wire coming from the battery? Behold, there was a 25 A fuse located in a wire connected foward to the snow blade actuator. I now have a life time supply of these special fuses for $14.95. And yes, it was burned out and all is working today.
PA, John
   / Kubota snowblade problem #9
Glad to hear you gor it going. Be sure those fuses say buss or little on them. There are counterfit fuses out there and they will not blow, they will cause a fire.
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
Wolverine Mini Skid Steer Pallet Forks (A50514)
Wolverine Mini...
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
