Kubota snow blower problem
   / Kubota snow blower problem #1
stevern
mt
jd 1010
I have a kubota mower with a kubota snow blower attachment-model no TG2742 Serial NO 70101202
Used today- worked great then almost done , stopped shooting out snow, cleared all snow out- both front augers turn fine, the chute auger pin is gone but stuck-it will not turn- I looked for any rocks or partially stuck shear pin. still wont turn. Took off the chain guard behind the unit, it runs fine also.
Any suggestions
   / Kubota snow blower problem #2
Bring the entire unit into a warm environment, if such is available. It could be ice/wet & frozen snow that has blocked/locked up the fan.
   / Kubota snow blower problem #3
Agree with Oosik - may be that the fan is frozen if your temps were cold enough.
The fan on my 50 hp skidsteer will freeze up in single digit temps sometimes when I stop it for some reason. I carry a hammer under the seat and just whack/tap the fan blades a few times to break the ice bond
It is in my garage now, but it was not that cold out today-28-30 F. I'll let you know
   / Kubota snow blower problem #5
I used a 3-point snow blower on my mile long gravel driveway for 25+ years. My neck & shoulders would get so darn stiff & sore. Then I bought a new, much heavier tractor in 2009 along with a heavy duty rear blade. NO MORE rear blowers for me.
Anyhow - I found that if the temps were around freezing - I had to leave the blower running any time I stopped the tractor. If I shut the blower down there was a good chance the fan would freeze up and one of the shear pins would blow. It did not take an awful lot of snow built up in the fan/chute area either. Water/wet snow would run down the chute or accumulate in the fan housing - freeze - one of the shear bolts would pop.
I always carried a heavy rubber mallet in the bucket. Like seville - whack the fan with the mallet and break the fan loose. There were still times when I did have to shut the blower completely down to clear ice that built up behind the augers.
well, went and looked after all snow was gone- one big rock jammed under the bottom blade-got it out-thanks for the info.
   / Kubota snow blower problem #7
I don't think your augers should turn freely if your fan is stuck. Kind of sounds like a gearbox issue.
   / Kubota snow blower problem #8
Sorry just seen you posted the issue!
   / Kubota snow blower problem #9
To the OP - don't feel bad. I would always do a FOD walk down the driveway - just before the first snow. I'd consistently miss a rock, limb, etc and blow a shear bolt or two the first clearing of the driveway. After that - a shear bolt or two the entire remainder of the winter.
Yes, awhite is correct. If the fan turns and the augers do not or vice/versa - there is a blown shear bolt somewhere.
OEM shear bolts can be expensive. I ended up getting Grade 2 machine bolts from the local hardware store. They DO blow a tad bit easier but are a world less expensive. Just get the correct length & diameter and go like smoke & oakum.
   / Kubota snow blower problem #10
First time I broke a shear pin was when I stuck the neighbor lady's garden gnome in my auger. :muttering:
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
19?? Asphalt Roller (A52377)
19?? Asphalt...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
2019 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2019 CATERPILLAR...
