Kubota rtvx1100
   / Kubota rtvx1100 #1
dra1
new holland tn 55d
My rtv will not move unless it is in 4 wheel drive
   / Kubota rtvx1100 #2
Jack up the rear and block the front wheels. place the vehicle in 2wd and see if the rear wheels move without resistance when you press the go pedal. I had a BX that someone stomped on the diff lock when the wheels were spinning and it grenaded the rear differential. It would only move in 4wd. What other symptoms did you have prior to this happening? Has the unit been serviced in accordance with the owner's manual? Are you using Super UDT and [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] filters on your transmission? Is the transmission case full as well as the Hydro tank under the seat?
2021 HITACHI ZAXIS 35U EXCAVATOR (A51242)
2021 HITACHI ZAXIS...
2022 KUBOTA KX040-4 EXCAVATOR (A51242)
2022 KUBOTA...
VOLVO SE240LC-3 EXCAVATOR (A51242)
VOLVO SE240LC-3...
UNUSED JCT SKID STEER QUICK ATTACH SNOW PUSHER (A51244)
UNUSED JCT SKID...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
