Kubota RTV900 no forward or reverse
   / Kubota RTV900 no forward or reverse #1
boyler
chicago il
Kubota RTV 900w
Looking for a little bit of help on Kubota RTV 900W I have.
Its a 2005 model year with approximately 1018 hours on it. It is used to groom cross country ski trails with a set of Camoplast tracks. I was not driving it at the time but it was apparently going along and then just started to lose momentum and then stop. It was in medium 4wd at the time. (wrong gear imo)
Here is what I know about the unit.
-engine starts and runs fine, I removed the shift linkage cover from the HST and can see the input shaft spinning while it is running. Both shift fork/synchronizers move freely and the linkage is adjusted per Kubota repair manual. I have even gone as far as to manually shift the synchros while it is running and there is no reaction.
I installed a gauge into a port from the charge pump on the back of the HST per the manual, spec is somewhere between 3300-3800 psi. I have ZERO! I tried this in 2wd high if I remember correctly. The manual had a different port for forward and reverse and specified different gear ranges as well. Neither showed any pressure while running.
I then removed both high pressure relief valves and inspected the o-rings, spring and bore for damage. None found. Manual continues on and says HST is not serviceable. New one is $7500 from local Kubota dealer.
Fluid is clean, free of debris, chunks, metallic pieces etc. Filter is oem, no issues noted. Approx 400 hours on current UDT fluid.
I can see that the use of tracks, a trailer groomer and high speed could have killed this transmission but I guess I'm looking for more physical evidence that something broke. I was reading through the parts and service manual and was thinking of tearing down the back of the transmission and removing the valve block to inspect the brass thrust plates for wear. That is about a $750 repair.
I have searched online and come up with very little which is part of the reason I joined today. Any advice or information is appreciated. Thanks
Rob
   / Kubota RTV900 no forward or reverse #2
:welcome:
To the forum from Alabama. My son lives in Northwest Indiana and work for a steel processing plant in East Chicago.
   / Kubota RTV900 no forward or reverse #3
Welcome...Don't know what the problem is but there have been HST rebuilds done for some here. I'd check with a dealer, $7500 for a new replacement is downright obscene. Might as well buy a new one.
   / Kubota RTV900 no forward or reverse #4
I don't actually know...but here are ideas that occurred to me...
maybe a blockage in hydraulic input has occurred...filter or other input clogged
there has to be a hydraulic pump there somewhere...hope it is not integral to transmission...
I reread your post...you have the parts manual and seem to know your way around stuff...I would look for why there is no hydraulic pressure.
   / Kubota RTV900 no forward or reverse #5
I'd bet the main pump is worn out. Remove the cover at the rear and inspect.
   / Kubota RTV900 no forward or reverse #6
1080 hrs is way too few to have a worn out pump unless it is employee driven (abused). I would be looking at the differential or transfer case. There are also some relief valves that may have failed.
   / Kubota RTV900 no forward or reverse #7
I've read where the axles turn in the wheel but doesn't turn the wheel. Sheer pin broke?
   / Kubota RTV900 no forward or reverse #8
Iirc ebay has companies listing rebuilt hydro stat units. As you noted somebody has been lugging the transmission. "Shifting gears" doesn't really shift gears but varies the amount of swash plate travel with relation to throttle .
We had a couple of 900 units at work. The relief valve in the transmission was factory set to lockup the wheels when the throttle was released. The reverse torque "chuck" was wearing the splines in the front drive shafts and the CVJ bearings.
   / Kubota RTV900 no forward or reverse #9
I came across this post the other day when trying to find a solution to my problem. My symptoms are exactly the same as you described in your post. I see that you had this issue a few years ago and I did not notice any useful answers.
I am hoping that you have since resolved your issues and be kind enough to share what the problem was or how you fixed it.
   / Kubota RTV900 no forward or reverse #10
Did you get it fixed? I have run into this. If all of your linkages are all good then it is usually 1 of 2 things (I've had both happen to me) 1 The differential failed and 2 like has been said is the HST. I've taken the HST apart once before and replaced all the brass valve plates (some people call them swash plates but that is incorrect, swash plates adjust how much volume a variable displacement pump pumps). If i remember correctly there are 2 variable displacement pumps and one fixed displacement. When I took mine apart the second time (first time was due to differential) there was a failed bearing on one of the pumps, the ball bearing were all in the case, and the valve plates were pitted due to cavitation. I could not see the bearing on the back pump because something it was holding it on in the differential case which i did not take apart. about a week after doing this all the kubota stopped moving again when i was going up a hill.
I'm prepping the machine now for tear-down, maybe i'll take a bunch of photos and follow through with this. I would test all the pressures, I think there are 3, forward, reverse, and charge. Make sure you test the charge pressure, I don't have the exact spec on it right now but should be between 100-200.
if you have 0 pressure in the forward and reverse ports it is unlikely the diff.
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
Feteral 8"x60' Transport Auger (A50774)
Feteral 8"x60'...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
UNUSED AGT DM20 EXCAVATOR (A51243)
UNUSED AGT DM20...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
