murphyzoo
I'm having trouble with a new-to-me 2005 Kubota RTV 900. It seems quite under-powered. I'm well aware that this diesel RTV is meant as a work-horse and not a speed demon. Our main goal with this is to be able to drag our horse arena with the ABI Arena Rascal Pro. The drag is built so that a 750cc ATV should be able to tow it. The ABI company said that a RTV900 should be more than sufficient.
The engine appears to run ok - it revs up and sounds smooth, but just feels underpowered. We have a slight hill on our property and the RTV has a hard time going up it in M and sometimes in L. If we stop on the hill, it's near impossible to get going again. Under load (towing the arena drag), it is very apparent the RTV doesn't have the power it should - we know it isn't a tractor and aren't trying to do something an ATV couldn't do. We also seem to notice that it loses even more power when it fully warms up. I'll drive it down our street in H gear and use a GPS to measure the speed. Once warm, the speed will be 3-4mph slower (this seems odd to me).
We picked it up with about 2400 hours on it. I did a full fluid change using Kubota SuperUDT2 and Kubota brand filters. I added a high-rise air intake and have checked the exhaust spark arrestor. I also added the hand-throttle option based on my local dealer's recommendation so that I can rev up the engine separate from driving the transmission. I've read several of the articles on RTV's with low power, so I know not to just mash the throttle to the floor. With the break off and the RTV in neutral, it rolls smoothly, so I don't think the brakes are an issue.
What else should I check on this RTV? Would you guess this to be an engine power issue or a transmission problem getting the power to the wheels? What's the best way to find out where the issues are?
