Kubota RTV500 Air pre filter
   / Kubota RTV500 Air pre filter #1
CCarr1945
Anderson Co., TX
1952 Ford 8N, Kubota 500
The inlet pipe to the RTV500 air filter canister appears to have a foam filter stuck into the top. I found this while evicting a used bird nest. I can't find this filter listed anywhere and can't get it out with out disassembling the intake pipe and hose.
Any ideas on how I should proceed? What is the filter replacement? Anyone know about a 2016 steering shaft recall?
   / Kubota RTV500 Air pre filter #2
The foam filter keeps the birds out, dogs,cats whatever, grab the filter and pull it out, it's only held in by friction, wash it out let it dry and push it back in, I've had my 500 for 8 years, pull it out once a year and wash it. The steering shaft recall was only on certain serial number machines, mine wasn't included, the dealer said the shaft could snap off at the steering wheel (heaven forbid) because the shaft was too thin at the wheel. I'd call the dealer with your serial number an get an answer.
Thanks for your reply. I took off the hose and fished out the remains of the filter material. It was almost completely disintegrated. Probably from heat. Half was in the pipe and the rest had made its way to the paper filter.
Now the question. What was it? I'll probably have to make the drive to the Kubota dealer.
   / Kubota RTV500 Air pre filter #4
You probably will have to go to the dealer, I can't find it online. It's like the filter on a wet dry vac the black foam wrap for picking up water, just my 2 cents.
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
1 Bridgestone 255/70R 22.5 and 1 Toyo M-872 12R 22.5 Tires (A51573)
1 Bridgestone...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
