Kubota rtv
   / Kubota rtv #1
dra1
new holland tn 55d
How to remove axle from 2020 model kubota rtv x1100 rear axle
   / Kubota rtv #2
IRS? Remove wheel, brakes, provide support for the CV joint, remove upper and lower arm mounting bolts, knuckle case, then remove CV joint. Don't over-bend the CV joint during disassembly or reassembly. Similar to a car FWD CV joint procedure.
   / Kubota rtv
I have the wheel and hub assy off of the machine, now I need to get the axle assy from the transmission without damaging anything and need to know the proper procedures to disconnect from transmission
   / Kubota rtv #4
A CV joint will just slide out, usually when you remove the knuckle case. The knuckle case is the retainer. Try Youtub for car CV replacement it will be similar.
   / Kubota rtv
Thanks for the information. I was lost on what to do.
2008 CATERPILLAR 320D L (A52472)
2008 CATERPILLAR...
2011 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2011 FREIGHTLINER...
Has charger with it. (A51694)
Has charger with...
28013 (A50322)
28013 (A50322)
2014 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A52472)
2014 FREIGHTLINER...
