Kubota RTV X1100c battery going dead
   / Kubota RTV X1100c battery going dead #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
My good friend bought a brand new 2018 Kubota RTV X1100c model.If he lets it set more tan 7 days without starting it the battery goes dead.Anyone else have this issue?Dealer states might be the clock in the radio making the battery drain.Any thoughts?Thanks..
   / Kubota RTV X1100c battery going dead #2
I wouldn't think a clock would draw enough power to drain a batt in a weeks time. Use an amp meter and measure how much draw it has when shut off. My guess would be a bad battery. My gator alternator would not keep a charge on the little riding mower battery. I used a battery tender for many yrs but when the battery finally needed replacement I put a small car battery in it. Haven't had to plug in the tender yet, probably will have to during winter months.
   / Kubota RTV X1100c battery going dead #3
Use an AMP meter in line and start pulling fuses to narrow it down some.
Thanks for this info.I will pass it along..
   / Kubota RTV X1100c battery going dead #5
Dealer is an idiot. It’s a warranty problem if the radio is a Kubota unit; lean on the dealer or find another one.
   / Kubota RTV X1100c battery going dead #6
It's not the radio and/or clock.
Somewhere there is a parasitic load that is draining the battery.
Any dealer or owner installed options?
I too have an RTV X1100C. Mine too has a radio with clock. I leave it unstarted for months without issue.
Don't leave the key on and don't leave the climate control systems on, e.g., AC and/or fan.
SDT
   / Kubota RTV X1100c battery going dead #7
Does it have some kind of alarm system like cars? They drain a lot of energy from a battery. It does sound like a warranty issue and the dealer should fix it for you. It may just be a bad battery and checking for parasitic drain is the first item to check. If it has little to none (a diesel engine should really show no parasitic draw) then a load test of the battery might show the problem.
SDT
I spoke with him tonight,he has be leaving the climate control in the on position.Thanks..
No alarm system.He is going back to the Kubota dealer shortly to get this resolved.
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2020 JOHN DEERE 5125R LOT NUMBER 24 (A53084)
2020 JOHN DEERE...
1997 Freightliner FL60 Truck, VIN # 1FV3GJBC6VH725847 (A51572)
1997 Freightliner...
2011 PETERBILT 348 (A52472)
2011 PETERBILT 348...
2013 VERMEER VACTRON LP555 DT HYDROVAC TRAILER (A52472)
2013 VERMEER...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
