pdsrms
I'm considering purchasing the above RTV. I would like to attach a hydraulic dump cart which has a 24" piston.
One dealer says no problem. It will need a step-up fitting to mate with the difference in hose size. They say it will take longer to dump due to the RTV's smaller hydraulic pump than my L39 has. I know, quite a bit longer. About 15 seconds vs 5 seconds.
Another dealer says it should not be done due to the small hydraulic fluid capacity of the RTV. "It will burn the pump out due to loss of fluid."
Assuming the hydraulic dump piston is fully primed with fluid why would the volume of RTV hydraulic fluid matter? It's really a closed system to my mind.
