Kubota RTV- VHT ~~ Transmission "MAGIC"
   / Kubota RTV- VHT ~~ Transmission "MAGIC" #1
TWO GUNS
Platinum Member
SWAMPS OF LOUISIANA
The question was brought up this morning by a friend that is going to purchase his new RTV Monday. For I have climbed very few hills, with no problems. For where I work & hunt, is pretty-well flat ground, And have read several threads on the so called right way to use the "magic transmission" on the unit. What I did on my few trips to Mississippi, checking out some property, I don't remember what I did. . Now, his question was, for which I really don't have the answer, Do you push it to the floor and get the rpm's up and then back off half way, or do you just go half way down with the pedal to climb. So what is the RIGHT way to do it , Recon the question is for both of us, he will be using his for hunting the hills of Mississippi mostly .....All replys will be appreciated !!!!
THANKS ~~~~~
TWO GUNS
SWAMPS OF LOUISIANA
   / Kubota RTV- VHT ~~ Transmission "MAGIC" #2
Give them both a try...I think both methods will do the trick. Most folks probably do it the full throttle & back off way.
Good info on how the transmission works:
RTV transmission
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
Mission 6" Centrifugal Pump (A50121)
Mission 6"...
Kubota RTVX900 (A50121)
Kubota RTVX900...
2014 Nissan Juke Multipurpose Vehicle (MPV) (A51694)
2014 Nissan Juke...
3pt Scratcher (A50121)
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
