Kubota RTV 900 Rear Axle loose
   / Kubota RTV 900 Rear Axle loose #1
FTG-05
Elite Member
TN
Kubota L4330 GST w/FEL, Kubota RTV-XG850, Kubota ZD326S
Notices that my right rear tire and wheel were cocked this morning on my RTV 900, so I decided to take a look at it. As soon as I lifted the RTV off the axle and wheel/tire, the wheel/tire wobbled back into line again!
Took the wheel off and it looks like the axle shaft is loose in it's housing. Tightening the axle nut doesn't really do anything, so it must be a bearing or something else. Also, I can pull the axle shaft out an inch or so; when it's like this, the axle shaft wobbles around loose. (sorry for all the technical terms, hope I'm not confusing you!).
Anyone know the problem, the solution and any other advice?
Thanks,
   / Kubota RTV 900 Rear Axle loose #2
I'm not sure whether its the same problem, but there have been several threads dealing with the torque of the axle nut. I can't provide details, but Kubota apparently issued a service bulletin that increased the torque specifications. A low torque was causing wear that resulted in a costly fix.
Steve
2018 John Deere 9470R Tractor (A53342)
2018 John Deere...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
42008 (A51691)
42008 (A51691)
2021 Ram 1500 Bighorn (A53472)
2021 Ram 1500...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
