Kubota RTV 900 OEM Block Heater Question
   / Kubota RTV 900 OEM Block Heater Question #1
chado613
Bronze Member
Kingston, Ontario, Canada
IH 624, IH B414, Kubota RTV 900, Kubota M7060
I have a few questions if anyone could help me out:
1. Does the block heater regulate itself? Will it turn off if it gets to a certain temperature?
2. Is testing the element with an ohm meter a good test to see if the element is still working?
3. If replacing an existing heater, how do you get the existing element out of the engine head?
Cheers
   / Kubota RTV 900 OEM Block Heater Question #2
I don't have a block heater on my RTV. But I'll offer my generic experience with them.
1. Every one I've had heats non stop when power is applied.
2. Yes, an OHM check will tell you if it's functional. They are a simple electrical short.
3. Sorry, can't help you with removal. Ones I have dealt with replace a block freeze plug. Have a tightening system that swells them against the block hole and holds them in place without leakage.
Following your progress and hope you have success. Post pics if you can.
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2015 MACK GU713 (A50854)
2015 MACK GU713...
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2013 F-550 Bucket Truck (A51039)
2013 F-550 Bucket...
2025 GIYI Skid Steer Plate Grabber (A50322)
2025 GIYI Skid...
