Kubota RTV 900 front drive shaft replacement
   / Kubota RTV 900 front drive shaft replacement #1
farmer55952
Lewiston, MN
Kubota RTV 900
I just purchased a 2004 Kubota RTV 900. The front drive shaft (round shaft approx 2 ft long with U-joints on both ends) is shot. The U-joints are wore out and are sloppy with play.
I went to my local Kubota dealer and purchased a new drive shaft, it cost $105 plus tax. The dealer thought this would be an easy job to replace - me too.
I removed the kotter key and pin that hold the front drive shaft in place. The front drive shaft slides and neither joint is seized to the splined spindles. But, there is not enough play to remove the front drive shaft yet.
So, I unbolted the center hanger bearing and dropped that down, thinking that this would give me enough play to slide one of the drive shaft U-joints off - no such luck.
Please see the attached picture of the drive shafts (front and rear) and center hanger bearing. The front drive shaft is labeled 'XVCb-012'.
There must be a trick to doing this, I just have not found it yet. I appreciate any thoughts or input you folks may have!
Thanks!
   / Kubota RTV 900 front drive shaft replacement #2
You may want to try to post on the Orange tractor talks fourm as well.
   / Kubota RTV 900 front drive shaft replacement #3
Remove a ujoint.
If you don't have a ujoint press you could Use a larger socket and a smaller socket with a c-clamp and press one of the ujoints out. Larger socket to be pressed into and smaller socket to do the pressing. Take off the first pressed out side ujoint cap then send it back the other way until you can take off the opposite cap. It's what I used to do with Jeep axles.
I finally got this new front drive shaft on. In between the front drive shaft and the center hanger bearing was a rubber spacer/boot that was held on by a metal factory crimp clamp. I removed the clamp and rubber boot. There was now enough room to slide the drive shaft further up the splined shaft that was covered by the boot. Once I slid this up, the front U joint dropped off the front wheel splined sh. I slid the new shaft on and put the pin/kotter key back in to secure it. I put the rubber spacer/boot back on the splined shaft and used a hose clamp to secure it.
We are back in business!
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
Hotsy Pressure Washer (A51573)
Hotsy Pressure...
5ft Set of Disc Harrows (A51573)
5ft Set of Disc...
Halla LF30C 6,500lb LP Forklift (A51691)
Halla LF30C...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
