coobie
Super Member
- Joined
- Sep 19, 2004
- Messages
- 6,302
- Location
- S.Michigan
- Tractor
- Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
This is a quote from orange tractor talks website.(For those running RTV,s there has been a increase in the torque specs for the nut on the rear axle.We have had some spline failures here so this is likely important !Remove the plastic hub cover in the center of the rear wheels,remove the cotter pin and torque the nut 140 lbs(both sides)Kubota also has a new drive shaft available for the front drive (transfer case to front diff)It is reasonably priced and a vast improvement over the original)End quote.This happened to my 2006 Kubota RTV 900 this past week with 610 hours on the clock.It is in the shop as we speak.The repair bill set me back $932.Just a heads up you might want to retorque your rear axle nuts to 140lbs per side as stated.Hopefully doing this will save you a few $$ in a repair bill such as mine.
