Kubota RTV 500
   / Kubota RTV 500 #1
robinbr
VA
Massey 461 FWD; Ford 4610; 1939 Farmall M; Kubota 2360
What to do for loss-of-power after 50 hours?????? Dealers ignore that there is a problem???
   / Kubota RTV 500 #2
We just had one come in and it only had a rear brake that was to tight. When released it would out run a new one.
   / Kubota RTV 500
Thanks, that was the only advise the Dealer (Mt. Airy, NC) could give me. They checked brakes, parking brake, etc., reported no malfunction with brakes but still has a loss-of-power!!! Sent it home as Operator not knowing how to operate this unit. Give me a break!!!!
Sounds a lot like Toyota's accelerator problem however, in reverse!!!!!! Not a problem until it kills 19 people!!!!!!
   / Kubota RTV 500 #4
Is it the engine running weak? Can you actually hear the engine running funny? Is it a loss of HST power where the engine is running fine but it just doesn't pull up a hill well? Can you be a little more specific of the problem.
   / Kubota RTV 500
Engine starts without issue; will not rev up to normal rpm; vehicle will run on flat ground, but not at full throtle. Most noticeable is the fact the Vehicle will not pull hills without considerable effort. One can walk faster than the vehicle will operate on inclines in Low Gear. In 6 inches of snow will not pull on level ground.
This is completely adverse to the performance of the Vehicle when new and up to about 8-10 hours ago. Vehicle is well maintained, parked in enclosed garage, fresh fuel, etc.
No power, loss-of-power!!!! Hope this is more detailed, thanks for your help.
   / Kubota RTV 500 #6
Sounds fuel filterish.
   / Kubota RTV 500 #7
Check out the various post in the ATV forum on the RTV 500 throttle cable and servo adjustments.
   / Kubota RTV 500 #8
Agreed..Might be something mechanical though..Did you do the 50hr or the dealer?
   / Kubota RTV 500 #10
Pull the spark plug and see if it's gummed up or out of gap. If it is, then it can cause some of the symptoms you're describing (heaving, sputtering, loss of power). I had very similar problems with my Yamaha Rhino within six months after purchasing it. The gap from the factory was way off and the plug was trashed.
Toolbox (A51573)
Toolbox (A51573)
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53472)
3-Point Hitch Root...
2020 KUBOTA RTV...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
