Kubota Rototiller
   / Kubota Rototiller #1
ronjhall
Super Star Member
SW Oakland County Michigan
2, Kubota B2910 HST
While traveling around the country I have found a used Kubota Rototiller. It's a model FL1520C 60" width. Has anybody had experience with this model? Can I use it behind my 2910? What would be a good price for one in good condition? Thanks in advance for any responses.
   / Kubota Rototiller
Took some pictures of Rototiller. Anyone have information on [ornage]Kubota</font color=orange> tillers.
   / Kubota Rototiller #3
Ron, I don't know anything about Kubota brand tillers, except I had a Kubota salesman once tell me they were great (as if you'd expect anything else, right?/w3tcompact/icons/wink.gif), but I think the size is right for your tractor.
Bird
   / Kubota Rototiller #4
I've got one and it is great. Purchased about ten years ago.
Price will depend on condition - how well it has been kept and how much work it has done. Use mine behind a 43HP MF135.
PTO shaft is "Kubota" and expensive to repair.
   / Kubota Rototiller #5
I have a 42" Kubota tiller, I'll have to check the model number when I get home. I like it, but it's quite different from the ones I've seen. The final drive is a belt. I adjust the tension by moving the gearbox for and aft. Protection of a slip clutch without the maintenance - just keep a few extra belts.
   / Kubota Rototiller #6
We have suppplied numerous Kubota rotary tillers ,often used on other tractor makes. Typically they have curved blades instead of L shaped more commonly used in Australia.
The tillers are designed primarily for rice, where the soil is well tilled (soft), but they work well in most soils except where the going is very heavy. We always suggest the ground should be ripped first anyway.
Our customers seem happy with them , and we have very few failures. There is a shearpin on the spindle on most models, which will break if you overload it.
I read somewhere on the net that the curved blades take around 20-30% less power to drive than the L shaped ones,as the ground is sliced first before being turned. Blades are left and right hand. This means you can drive a larger tiller with less power, using less fuel in the process.
We sell them for AUD 875, or about USD450 to give an indication of price. If parts are needed, bearings and seals are aftermarket, blades are USD 5 ea. If other major parts fail, we have at least 30 or 40 units at any time for wrecking.We recently took a truckload for scrap (siezed /broken/beyond economic repair)
The linkage attachment is category 1, but you will generally need to cut a new shaft to size, and occasionally move the tiller mounting pins forward to accomodate tractors with very short linkage arms, too close to the PTO shaft.
For the price , I think they are a good thing.
   / Kubota Rototiller #7
The Kubota FL1520 has L type blades which is different to the rice paddy type hoes. I have both types of hoes including the FL1520. I bought mine from Elliotts in Dandenong so they were spld in Australia.
1978 LUFKIN TRAILER (A45046)
1978 LUFKIN...
2018 INTERNATIONAL LT625 (A45046)
2018 INTERNATIONAL...
Transmission-Allison 9820 (A45333)
Transmission-Alliso...
2014 UTILITY 53X102 DRY VAN TRAILER (A43004)
2014 UTILITY...
E-Z Trail 3400 Gravity Wagon with Honda EX27 9HP Gas Engine (A44789)
E-Z Trail 3400...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A44572)
2017 Ford F-150...
