Kubota Regeneration
   / Kubota Regeneration #1
Will_C
Veteran Member
Upstate N.Y.
Kubota L3560, Toro 52" and 60" ZTRs, Kubota RTV 900
Have had my L3560 for about 15 months. I have 150 hours on it. It has regenerated 6 times-each time has been around 25 hours plus or minus an hour or two. I was just wondering about others experiences. Probably 80-90% of the hours have been at 540 PTO speed using a RFM, a tiller, or a bush hog. Is this close to what people are seeing with their Grand L's?
Thanks,
Will
   / Kubota Regeneration #2
Yes, what you are describing sounds about right.
   / Kubota Regeneration #3
2019 Kubota 7060HD12. First regen at 27 hours, and second one today at 54 hours.
   / Kubota Regeneration #4
My L4060 has gone through 6 regens averaging 54 hours between. Mostly loader work, occasional mowing at PTO speed, and maybe 20 hours of winter plowing per year.
   / Kubota Regeneration #5
About what I've seen on my L4060 at 350 hours or so. Maybe 20ish hours between regens. No issues at all emissions wise.
   / Kubota Regeneration #6
A tractor mechanic told me if one is getting 25-30 hours between regens they need to stay with their fuel supplier. He said regens has really been a headache for repair people in trying to reduce regens for people trying to use the cheapest fuel they can find if it is labeled for a diesel.
   / Kubota Regeneration #7
Has anyone tried those additives for DPFs? I've seen on other forums, people using this stuff with very good results. It helps with the regeneration process.
This one is from CRC but for some reason is only listed on the EU site and not on the US site.
CRC WebSite: Product Detail
Liqui Moly also makes a similar product that works nicely.
Thanks to all who replied. It makes me feel better that my intervals are on similar to others. I don't know anyone with DEF tractor, so no information there.
Will
   / Kubota Regeneration #9
I wounder if anyone has ever worked right through a regen. process and not even realized it? Is a regen. count clocked on the tractors electronics for viewing?
   / Kubota Regeneration #10
I have worked thru the cycle on mine a coupe of times. Did not know it was doing it thing until I smelled the brunt paint smell just befor it got over
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A51039)
2017 Ford F550 4x4...
HONDA EU2200EI INVERTER GENERATOR (A50854)
HONDA EU2200EI...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
PALLET OF BRAKE AND AXLE PARTS (A50854)
PALLET OF BRAKE...
