I have two closed center remotes on my L3940. One for the hydraulic top link (great addition), other to angle rear blade or other options which may come in future. FYI, I paid $425 for each one, plus tax, and that included installation.
not to sound stupid!! But I AM!! What do you mean by a rear remote? And how is that different from a "Power Beyond Valve"?? I was told I need a power beyond valve to run my demolition hammer when connected to the back-hoe. I have a 2001 L35 TLB. I have had my hammer for 2 years and cannot get the dealer to order the power beyond valve parts. He says he has no idea on what to order!!!
From what I can figure it is just the outside housing (output side) of my controle block (for the hoe), that diverts the oil diffrently than what is there now.
Unfortunatly I don't need the hammer anymore (hired the work out, couldn't wait)
but I'd still like to either figure it out or sell it
Your remotes are "open center", not closed center.
So where does the terminolgy open center come from? Thanks. Philip.
In open center valves, hydraulic fluid flows through the in and out ports when the valve is in neutral. In closed center valves, flow between the in and out ports is blocked when the valve is in neutral. In all cylinder valves, open or closed center, the cylinder ports are blocked when the valve is in the neutral position. In motor valves, the fluid is free to circulate between the work ports when the valve is in neutral, allowing the hydraulic motor to coast.
