Kubota RCR-72 Blades
   / Kubota RCR-72 Blades #1
GarthH
Saskatoon, Saskatchewan
Hi all
I notice the blades from my old finishing mower have been discontinued - 70050-93168. Our dealer actually have some on the shelf but want over $800 for the set, I know their valuable but not that much.
On one Kubota dealer site it lists a 70050-93169 as a blade as well but I can't find a detailed description or a drawing to make sure it is the same. I have not found that part number available either.
The blade is 25.5" with a 3/4" x 1 1/4" hole. On the mower there is a oval piece that holds the blade solid, not sure why the bolt itself is not enough.
I'm search for a 25 1/2" blade, I think I can get a local welder to make the oval opening in it.
Any suggestions?
Thank you again.
Garth
   / Kubota RCR-72 Blades #2
Looks like the 70050-93169 is the 3 blade set for the 70050-93168. The 93169 is not showing NLA so may still be available but just not in stock as compared to the 93168 they are showing NLA.
2-Wheeled Heavy Duty Trailer Frame (A49251)
2-Wheeled Heavy...
10-16.5 SKS9 Tires (set 4) (A49251)
10-16.5 SKS9 Tires...
10ft QA Snow Pusher (A49251)
10ft QA Snow...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A46683)
2009 Peterbilt 384...
2017 Ford Explorer AWD SUV (A46684)
2017 Ford Explorer...
Case IH 1063 6 Row Corn Head (A49339)
Case IH 1063 6 Row...
