Kubota power steering
   / Kubota power steering #1
jackF
East Texas
2Kubotas/L185/B6000
I am in the process of adding power steering to my Kubota L185
I am using '65 Mustang parts. Instead of installing a separate
pump I plan to use the tractor hydraulic system.
Has anyone else tried this? thanks, JackF
   / Kubota power steering #2
</font><font color="blue" class="small">( I am in the process of adding power steering to my Kubota L185
pump I plan to use the tractor hydraulic system.)</font>
One reason for a separate pump in steering hydraulics is
the main tractor hydraulic system being open center. This
complicates articulating the steering cylinder and other
equipment cylinders at the same time. Even if the tractor
system is closed center you will still be sharing pump flow
between the steering cylinder and others in the system when
operated simultaneously.
As a steering cylinder typically does not need much flow volume
it may be easier adding a separate small pump -- particularly
when faced with the potential of upgrading the existing
tractor hydraulics to power beyond valves.
   / Kubota power steering #3
Not that it makes it right for your situartion, but my L3830 uses the same hydraulic system for the PS as everything else. On the other hand, uhmgawa may be correct in that your hydraulic pump may not pump enough volume to handle the PS too.
Perhaps you can find out the volume of that pump and it will help you decide whether to go with a separate PS pump.
Chris
2018 Allmand Light Tower (RUNS AND WORKS) (A50774)
2018 Allmand Light...
2004 Airburner T-200 (A50121)
2004 Airburner...
2010 International 4400 National Crane 300C 56ft 8 Ton Crane Truck (A50323)
2010 International...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2016 Hino 195h Truck, VIN # JHHSPM2H5GK001607 (A51572)
2016 Hino 195h...
