Loader Kubota Pallet forks don't fit right.
   / Kubota Pallet forks don't fit right. #1
rglaser
Bronze Member
Waynesville, Ohio
Kubota B2630 & ZD323
So, after several years of doing without because they are so expensive, I finally got a set of kubota pallet forks for use with the kubota quick attach on my B2630 with LA403 loader. Very dissappointed that the right side pin requires serioius hammering to get it to go in. Tried filing off some of the paint inside the holes on the fork frame which made it only slightly better. This is not my idea of a quick attach (need tools). And I imagine it is going to be very difficult to remove. Emailed dealer and their response was that it would loosen up with use. Debating my options of return for refund, exchange for new frame in the hope that it won't have the same problem, or try to live with it in the hope that it will indeed loosen up with time.
Thoughts?
Thanks,
Rob
   / Kubota Pallet forks don't fit right. #2
Something must be bent. My forks go on and off very easy with the quick attach system just flip the lever. If yours is not check over very close must be bent or out of whack some how.
   / Kubota Pallet forks don't fit right. #3
Thoughts?Thanks,
Rob
Does the bucket go on quick and easy? no hammering? if so, then I would focus on the pallet forks. the opening my be slightly out of spec.. funny thing is we hear of more "sloppy fit" of SSQA implements than too tight. Of course an angle grinder would fix pretty quick.. be careful though. I would not hammer much on the pins, I would fix the forks. It would be good to have another bucket or SSQA implement to try (neighbor?) so you know for sure it is the forks not something twisted in your adaptor, but I am assuming your bucket goes on and off easy?
James K0UA
Yes, bucket has gone on and off with ease since it was new and was expecting same from forks.
   / Kubota Pallet forks don't fit right. #5
I think this actually happens a lot in the ss world but so many of those units have some form of automated attach that is fairly strong and does not care. But for manual quick tach I have had to grind material away as k0ua says many times so that you did not have to beat up the pins to bad.
   / Kubota Pallet forks don't fit right. #6
I would grind a little at a time and try it each time.. be careful dont take too much unless you have a welder.. remember you can take off metal with a lot of things, but you need a welder to put it back
James K0UA
   / Kubota Pallet forks don't fit right. #7
It sounds like you have the Kubota Pin type Q/A. Look very carefully on where your clearance issues are, insert a longer matching rod into the suspect bushing and give it whack as to coerce it in the direction you need. Welding has the tendency to pull things out of perfect alignment, even with jigs. It is aggravating but may be able to be fixed rather easily.
Thoughts?
Thanks,
Rob
   / Kubota Pallet forks don't fit right. #8
Aha. so this is not SSQA then? I forgot about the propriatary attach on some of the smaller Kubota's. sorry. I am sure it can be fixed though as magicheater suggests
James K0UA
   / Kubota Pallet forks don't fit right. #9
My Kubota QA pins fit a little tight, too. Currently we only have the bucket for the FEL, so I haven't had it off/on, just put it on the one time. I figured a bit of gentle grinding inside the holes would fix it.
   / Kubota Pallet forks don't fit right. #10
That is one way to do it but taking metal off is only the equivalent to wear. Kubota brackets are only 1/4 material. A slightly more than gentle tap is all that is needed to bring the circumferences into alignment, Sometimes a bit more. Grinding will work too, if needed. This works on other colored tractors as well. :)
STORAGE FEES (A52141)
UNUSED AGT TIRE CHANGER (A51244)
UNUSED AGT TIRE...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
