Kubota MX5400/MX6000
   / Kubota MX5400/MX6000 #1
mr2143
PA
None
I have been waiting for these models to arrive for quite some time. They seem to be the perfect size for what I need. Requirements are cab, front end loader, and backhoe. Why are backhoes not an option if a cab is added?
   / Kubota MX5400/MX6000 #2
If I recall on the Ls there wasnt enough room between the hoe & rear window without some extension bracket pushing the hoe further back. I'd assume it would be a similar situation.
   / Kubota MX5400/MX6000 #3
I considered the MX model and the L model in the 54 and 60 hp size. One thing I had issue with was no way to open the right door from outside of the cab.Might not seem that big of deal but hooking up to rear implements often I find need to raise or lower the lift and do so with rear remote implements also. With no latch to open door from the outside you would have to be sure to open the door before leaving the cab. That does not show as option in building the tractor either. Also wanted side windows that opened which was a big reason did not go with JD 4000R series. Dealer did say they could order right door latch as a "part" even though not a factory option on the latch. Would suggest you do so.
TMA (A49461)
TMA (A49461)
2014 Ford Escape (A50323)
2014 Ford Escape...
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2000 FORD F650 SINGLE AXLE DUMP TRUCK (A52472)
2000 FORD F650...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
