KUBOTA MX5100 TOWING POWER
   / KUBOTA MX5100 TOWING POWER #2
Manual says 7700 lbs, Drawbar load is 1650 lbs, but I am sure it will pull more than that..
I always get confused with weights conversions so I asked google and these are results which suggest about 2-3 ton can be pulled.
It depends upon which "ton" you mean. 1 long (or gross) ton = 2240 pounds (UK) 1 short (or net) ton = 2000 pounds (US) 1 tonne (i.e., a metric ton) = 2204.6 ...
1 tonne = 2 204.62262 pounds.
How many kilograms make 1 metric ton? In: Weight and Mass [Edit categories]. Answer: One metric ton (also known as a 'Tonne') contains 1000 kg, or 2204 ...
Answer:
1 tonne (i.e., a metric ton) = 2204.6 pounds
In the United States, when people say "a ton," they're thinking the short ton, or 2000 pounds.
There are various dump trailers on the market and they must weigh a ton too, so does not leave much for dirt ton carrying capacity?
ANY COMMENTS FROM ANYONE WOULD BE HELPFUL
   / KUBOTA MX5100 TOWING POWER #7
my mx5100 hst can pull a 4 bale hay trailer loaded with 5 by 6 bales an 1 on the loader no sweat.so id say thats close to 7000lbs towing or more.
SELLICK S80T4E-4PS ROUGHT TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2006 FORD F-250 (A52472)
2006 FORD F-250...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
2015 FORD E-350 14 PASSENGER VAN (A52472)
2015 FORD E-350 14...
