Mowing Kubota MMM blades
   / Kubota MMM blades #1
Toyboy
Platinum Member
Hayward Wi
Kubota BX2230D
I just finished cleaning, changing blades and PM'ing my RCK 60B MMM. My question is I've not been able to determine if the 3 blades have a specific orientation to each other or not??? My old Case 446 deck specified an orientation but not this one that I can see. Is there a right or wrong way to install them??:confused: Thanks
   / Kubota MMM blades #2
On mine they are all the same. I would bet money yours are, too.
   / Kubota MMM blades #3
There will be notches on the spindle assemblies, so as long as you get them in the proper notches so you can tighten them down properly, you won't have any problems as they are staggered and the blades will rotate on the spindles anyway, so there really isn't any way to set them and guarantee they will stay. Torque them to about 75-80 foot pounds. This is probably to reduce shock if you hit something and reduce chances of damage. I hit a boat anchor once and no damage was done.
We had an old Massey Ferguson with gear drive as opposed to belt and the blades had to be synchronized or they would hit each other.
   / Kubota MMM blades #4
After 10 minutes of mowing, they will move out of orientation! Cub Cadet used to recommend the outer blades at 3 o'clock and 9 and inner blade at 6 &12. I tried this on my RCK60-24B deck and as I said, shortly thereafter they sought their own! I've never noticed any difference in quality of cut, so I no longer fuss with it!
   / Kubota MMM blades
I'm not sure I was clear on the blades. On the 446 they wanted the center blade in line w/bottom left blade on rotation...like tip to tip... and the same tip to tip on the bottom right when the center was rotated. So in short, the bottom left and center together would make a strait line and likewise when the center was rotated with bottom right, like two sides of a pyramid. According to Case, this orientation of the blades to each other would eliminate uncut lines. Kubota does not say anything about that as far as I can tell. The notched washer is fine and so is my torque which I set at 75#
   / Kubota MMM blades #6
Fit them back on the spindle(s), at will. There is no specified orientation.
   / Kubota MMM blades #7
Yes, you were clear, but no matter how you set your blades there is nothing to keep them from rotating on the spindle other than friction and when/if this happens, it won't affect anything. I got mine back from the dealer once and while doing a check on my blades noticed the one on the left could be rotated by hand and the cut quality was still good with no strips. I put it in my garage and torqued it where it was.
I have had mowers with keys or stars in the blade to prevent rotation, but there is nothing on the Kubota like this.
   / Kubota MMM blades
OK, gotcha.:thumbsup: Just thought I'd check it out. Thanks to all.
   / Kubota MMM blades #9
The only thing that I have seen in some Kubota manuals, is after each sharpening to rotate the blades as to which spindle they are mounted on so you can kind of balance the wear on the blades.
David Kb7uns
   / Kubota MMM blades
I spotted that but was in a quandary about orientation which has been cleared up.:thumbsup:
What do you guys fine best to use on the spline shaft..... grease or never seize? I'm leaning towards never seize.
My big problem is that the machine was delivered to me with snow blower mounted and we don't have any snow!!! So now I've got way too much time on my hands to sit around and think of all this goofy stuff:D The darn thing is all dressed up with no place to go until switch over from snow to grass:( So in the meantime I've been PM'ing everything I can think of:laughing:
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2013 Jeep Patriot (A50324)
2013 Jeep Patriot...
2015 Ford E-350 Passenger Bus (A50323)
2015 Ford E-350...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
